Hi All,
Recently tried Colibri from TT and couldnt get the image capture mechanism to work.
I then found via a discourse post where @mostapha reccomends the Fly component which was reintroduced from legacy.
I followed the above video (thank you for this - it’s the clearest explanation i can find for iterating image capture in GH).
But my issue is that it is iterating before the image capture takes place - the image is produced but the coloured visual output (sunlight for example) is not being included. I note that this is specifically tackled by introducing boolean logic to only take the image after the calculation is completed - i followed the same logic but to no avail.
As a temporary fix - i found that the Colibri iterator connected to the Fly ID & LB Capture View components generate an image of the results before moving onto the next iteration.
It pains me to use two components - i’d love to have a clean Ladybug only canvas.
Wondering if you have a grasshopper example file & a working LB Fly iterator saving images of say the Direct Sun Hours analysis?
thanks so much in advance!
