Pollination Panel does not show the Studies to Run
Opening Pollination panel on two systems, it shows a blank white page after choosing the Recipe for analysis while everything works well on the other one as shown below. I wanted to see if this issue is something about Pollination or should be find somewhere else.
I appreciate your help.
MaHa
Hi @mahagh, the second screenshot is from an older version. Updating the Rhino installation should fix the issue.
