Pollination recipes sim are not running or working
I’ve tried to run various recipe sims using Pollination, including daylight and energy, and every time there is either an error or Pollination just cancels the sim. Pollination doesn’t provide any information to diagnose the problem and seems very unstable and unreliable. Is anyone else struggling with Pollination and finding it more complicated and unreliable to use than HBTs in gh?
Hi @robm,
The reason that your simulations on Pollination are being canceled is that you are trying to run them under your personal account (robm) and you have exceeded the storage quota.
You should try to schedule them under a project under the HOK organization. That should resolve this problem.
I agree that our debugging UI can be improved. We have not exposed the message in the UI.
I disagree with this one. Here is the stat for successful runs on Pollination during the last week for more than ~15,000 simulations.
There are cases that the model is invalid or the account runs out of quota and the simulation gets canceled but for cases that the study is set up correctly, and based on the success rate that I copied above, I would consider it very stable and reliable.
As of now, the LBT Grasshopper plugins are more flexible for setting up the metadata, post-processing, and visualizing the results. The main advantage of using Pollination for Ladybug Tools users has been offloading the work on the geometry to the Rhino plugin. You can use the PO Model component to bring your Pollination model to Grasshopper and use it as an input to Ladybug Tools.
Here are 3 slides that show the before and after.
If you are comfortable with using Grasshopper then you can bypass the need to use the Rhino UI for running the simulations.
Going back to your initial question, if you can reschedule your simulations under an organization project, and provide us with the URL/ID of the failed simulations we can help you debug them on a case-by-case basis.
Thanks for your quick response Mustapha, and I’m keen to see if your help can move me out of the 0.1% of failed sim runs.
Unfortunately our company profile isn’t letting me add projects, only studies. Can you advise why our company profile can’t add projects. Secondly, if you’re saying I can’t run sims on my profile, but can add projects, it’s still not helping us run sims using Pollination.
Could you give me clear advice how I can set up projects on our company profile please?
I thought we had paid for a license but it seems the set up isn’t right if we’re unable to set up projects - can you check please and update your system if needed?
PS - please be mindful of sharing company information on a public forum.
Thank you, @robm. I moved the conversation to a private message. Let’s set you up for success!
