Hy,
On revit, at the end of the export I can’t select .HBJSON.
He just prpose me .DFJSON…
How can I do this ?
When you use the extruded geometry calculation the model will be exported as a DFJSON file. If you use the detailed geometry calculation the model will be exported as a HBJSON file.
There geometry calculation method is selected at the first step of the process. The default is set to the extruded mode.
Are DFJSON and HBJSON files the same to Honeybee/PollinationCloud or do I need to translate them?
DFJSON format is the native format for Dragonfly. HBJSON is the native format for Honeybee and Pollination Rhino plugin. You can always translate the DFJSON file to HBJSON without losing any information.
If you use the Rhino plugin it automatically translates the DFJSON to HBJSON during the import process.
