Pollination Revit Plugin Create Rooms - Missing Windows
I am working with the trial version of the Pollination plugin tool for Revit and I noticed the Create Rooms tool is not “reading” the project apertures, specifically the windows from the Revit Model exterior walls when I create the geometries using the Rooms as source. In the other hand, when I use the Areas as source I can see the windows, so I am not sure what could be the problem.
This is a discussion I started talking with Mostapha through an email conversation.
Hi @santimt88, I just sent you a private message to continue the conversation there. I will update this topic later once we know the answer.
Hi!
Any news on this? happened to me as well. Thanks!
Hi @greciacastillo,
Could this be the reason? Are you changing the export status to Export from Ready to review?
If that’s not the case, then I will need more information about your project to be able to help.
