pollination-streamlit-XX code location
Hi Pollination community,
I’m currently experimenting with building Streamlit apps. Looking at the
Get and Display Model (by @nicolas) the following packages are used:
from pollination_streamlit_viewer import viewer
from pollination_streamlit_io import get_hbjson
But I can’t seem to find them on GitHub, are they currently closed source, or am I looking in the wrong place?
For context - I was hunting for an epw equivalent to get_hbjson
Thanks in advance,
Charlie
Managed to solve my specific issue around epw upload handling from the weather report app code here:
epw_data = st.file_uploader('', type='epw')
if epw_data:
    epw_file = pathlib.Path(f'./data/{epw_data.name}')
    epw_file.parent.mkdir(parents=True, exist_ok=True)
    epw_file.write_bytes(epw_data.read())
else:
    epw_file = './assets/sample.epw'
global_epw = EPW(epw_file)
Hi @charliebrooker,
Yes. We kept the repositories on GitHub closed however the code itself is open and can be accessed from PIPy.
Glad that you found the answer to your question. @antonellodinunzio has also created a new epwmap component recently that can come handy in the future.
