On the left shows our building in Pollination. The orientation here matches project North. On the right shows our buildings True North Orientation in Revit. It is not a vertical alignment like True North. Please advise.
Thank you for pushing this up. I see your point. I agree that this is nicer to be automated but for the time being, what we can do is to expose an input for north orientation in the app that allows you to set it to your desired value between -180 to 180 or 0 to 360. Would that address your concerns?
We currently don’t keep track of the north in HBJSON file. This is by design and to make it possible to run orientation studies, etc. We are planning to add a field for project information that should include the north rotation.
Either way, after the update, the user will be able to adjust the north direction directly in the app regardless of running them from the web, Rhino, or Revit.
Hi, @moses-woolpert, I added the north input to the app. Give it a try and let me know if it works as expected.
NOTE: The north arrow in the web-based 3d viewer does NOT change based on the input value. This is only a visualization bug, and I will fix it at some point in the future.
