Pollination tab not showing in grasshopper after finalizing pollination installation
Hi i just installed the grasshopper plug-in 1.60.5 but when i go in grasshopper (Rhino8) i don’t see the pollination tab anywhere. Am i not following a special installation instruction ?
Thank you
Hi @oalh, welcome to the forum!
Did you get any errors when you opened Rhino/Grasshopper?
Can you check and see if this file exists on your computer? C:\Program Files\pollination\plugin\8.0\Pollination\Pollination.GH.gha
Hi @mostapha,
Thanks for replying,
It didn’t show any errors while or after installing neither when opening Rhino/Grasshopper.
Yes there is, it is here: “C:\Program Files\pollination\plugin\8.0\Pollination-GH\Pollination.GH.gha”
Hi @mostapha @mingbo,
I installed all the ladybug tools by single-click pollination.exe. But I encountered the similar issue as @oalh did. Moreover, there are many missing Ironbug components with errors showing:
 Priority: CategoryIcon
  未能加载文件或程序集“System.Diagnostics.DiagnosticSource, Version=8.0.0.1, Culture=neutral, PublicKeyToken=cc7b13ffcd2ddd51”或它的某一个依赖项。系统找不到指定的文件。
  FileNotFoundException
Object: Ironbug_SetpointManagerWarmestTemperatureFlow (level 1)
  调用的目标发生了异常。
  TargetInvocationException
Object: Ironbug_SetpointManagerWarmestTemperatureFlow (level 2)
  “Ironbug.Grasshopper.Component.Ironbug.Ironbug_SetpointManagerWarmestTemperatureFlow”的类型初始值设定项引发异常。
  TypeInitializationException
Object: Ironbug_SetpointManagerWarmestTemperatureFlow (level 3)
  调用的目标发生了异常。
Object: Ironbug_SetpointManagerWarmestTemperatureFlow (level 4)
  尝试读取或写入受保护的内存。这通常指示其他内存已损坏。
  AccessViolationException
Object: Ironbug_SetpointManagerWarmest (level 1)
  调用的目标发生了异常。
Object: Ironbug_SetpointManagerWarmest (level 2)
  “Ironbug.Grasshopper.Component.Ironbug.Ironbug_SetpointManagerWarmest”的类型初始值设定项引发异常。
Object: Ironbug_SetpointManagerWarmest (level 3)
  调用的目标发生了异常。
Object: Ironbug_SetpointManagerWarmest (level 4)
When I ran the simulation with openstudio, it showed "Solution exception:Failed to run OpenStudio CLI: " or directly crashed. I use Rhino 7 and it has updated to the latest version.
Hi @oalh and @youknowleft,
Can you try to use the Rhino installer instead? It seems to solve the problem for other users.
