I’ve run a simulation with pollination and have come across a few errors. Please find it here:
CLOUD:aurecon/Other/5eca0e3b-2676-4599-9146-b0f814dd17d3
I set off a job with 128 runs but it says it has returned 122/122 only. How can this be?
Although it says it’s completed the job there are runs that are still post-processing and have been for over 30min while all other runs have completed within 10 minutes. How can these be taking so much longer when the only difference between the inputs is a change of material? How can I successfully complete the post-processing for these?
(I suspect that the runs that are still ‘processing’ are the reason why I’ve only returned 122/128 runs) -
I also have 1 run that has failed but after going through the debugging i cannot see any error messages to determine the cause of its failure
Could I please have some advice on these? @mostapha @antoinedao
