Problem exporting vertical shafts from Revit model
Hi, thank you for the Revit plugin. Things look quite good so far!
I noticed a problem trying to export room volumes from a Revit model.
The room I want to export is hatched in light blue. The shafts highlighted with dark blue get exported as punctures in the room volume, but the shaft marked in orange does not. It is instead exported as a part of the room. I am not sure if I am doing something wrong.
The result looks like this:
Any hint on what I should do?
Thank you in advance!
Hi @ketan,
Thank you for reporting the issue. Can you share a sample room with us so we can recreate the issue on our side? It’s hard to say without testing.
Surely,
I have tried to clean the file as much as possible.
Please take a look and let me know if you need anything else.
https://drive.google.com/file/d/1wWrj1ZCoUo8mv0ocWOnmxNRCDPGyEChz/view?usp=sharing
Hi @ketan, Thank you for sharing the model. I tested your model and the shafts are exported successfully.
I imagine you are using an older version of the Rhino plugin for visualizing the geometry. Can you install the latest version of the Rhino plugin and try again? I believe that should resolve the problem.
