vinicivs
(Vinicius Aleixo)
June 20, 2024, 2:32am
1
hi everyone,
I’m having this problem after install this pollination version: plugins_release_PollinationGHInstaller-1.48.25
I’ve already tried to reinstall rhino and pollination a couple of times but the error persists.
there are something that I can do to fix this problem?
beyond that, the pollination tab didn’t appear in the ribbon too
thanks
rhino version 7.14
mostapha
(Mostapha)
June 20, 2024, 2:42am
2
Hi @vinicivs , have you tried to update Rhino to the latest service release? At least that’s my understanding from the error message. @mingbo is the one to confirm.
vinicivs
(Vinicius Aleixo)
June 20, 2024, 3:28am
3
hi Mostapha!
thanks for the answer, it worked!
I didn’t thought it would be something easy like that
cheers!
glinn07
(Graham Linn)
June 21, 2024, 12:47am
4
I’m experiencing a very similar error but I am running Rhino 6
Is it possible that GH plug in does not work with Rhino 6? Thanks!
mostapha
(Mostapha)
June 21, 2024, 1:39am
5
Hi @glinn07 , my understanding is that it should work but @mingbo can confirm.
mingbo
(Mingbo)
October 29, 2024, 10:22am
6
Hi @glinn07 , make sure you only installed the Pollination plugin for Rhino 6, that should work with Rhino 6.35.
