You can get it with the Versioner and, then, you should be able to set local folder paths regardless of whether the weather file already exists in your personal weather library.
How do you expect me to do this on all the machines at the firm?
What process is automatically adding them in for you such that you then need to manually remove them?
We will create a new installer later this week so you can use it to push a fix to all the machines.
I would consider this easy enough to do manually. Many other software including Revit has this limitation. I feel your pain because I have to do the manual removal frequently but it hasn’t been a blocker.
