Project Information - local .epw file
I have not been able to use the local file epw functionality in the “Project Information” interface.
Is this available yet or still in development? Obviously I can work-around so it is not a problem now, just wanted to raise the bug.
Hey @byron ,
I can’t recreate your issue by using the URL to the same EPW file on OneBuilding:
https://climate.onebuilding.org/WMO_Region_6_Europe/GBR_United_Kingdom/ENG_England/GBR_ENG_Bingley.033440_TMYx.zip
Could this be related to the permissions on your OneDrive folder? Are you able to use the URL from OneBuilding without issues?
Hi @chriswmackey,
what you are showing - pasting a url - works fine for me too. What I am reporting is the local file functionality.
when you say url/file path, I assume you mean any local path should work. Although not sure if that would still need to be a .zip file to include ddy, or would it be direct .epw filepath.
Did I understand the intend wrongly?
I used another local file path (not on Onedrive) with same error.
ps. In Rhino 8, I get this error when hitting the EPW map button
Hey @byron ,
It looks like, the way @mingbo wrote it, it has to be a path to a .zip file like what you would download from EPWMap. I’m able to import it successfully if I just point to the .zip file that I downloaded:
Generally speaking, the URL is the more reliable way to set the EPW because you won’t end up with a broken link if you open your 3dm on another machine.
With that said, @mingbo , we should give a better error message if someone points the Weather Urls/Files to something that is not valid URL or zip file:
I can’t recreate your Rhino 8 issue, @byron . It’s possible that you have an old version of your Rhino 7 Pollination plugins loaded into your Rhino 8. This would also explain what is going on over here:
Did you use Rhino 8 WIP at any point? If so, can you go to the Rhino 8 PluginManager and try reloading the plugins. Admittedly, I can’t remember exactly how to reload them but I remember @mingbo and @mostapha showed me how to do it.
For sure there is some clash happening with my Rhino 7. What is odd is that it is happening on 2 or 3 different machines that I have tried. I would think that maybe the installer creates an issue but since you don’t get the errors, that is not an option.
If I look at my PluginManager, everything related to pollination, environmental analysis and Ladybug all points into “8.0” folders, under ProgramData, Appdata and Pollination folders on my machine.
Not sure where the mixe-up is happening. I was not able to do anything regarding the “reloading” that you mentioned.
Is there a chance that you used Rhino 8 WIP at any point on all of these machines?
If so, I know that’s the reason for your issues. I just can’t remember how I fixed it. I think some post on the McNeel forum helped me. I’ll see if I can look for it later over there.
100% had it on my work laptop, but I doubt I had it on my personal. But maybe I am wrong.
I tired searching the McNeel forum but to no avail, at least for the 20min search I did.
Will persist more later in the week when I get time.
It seems the original local weather file problem in the Project Information has been addressed. Please let me know if the issue remains.
@mingbo, you are right.
Seems that this works just fine.
One comment is with the UI and the text. It asks for file path, but in reality you need to input a folder path, if you want to use local epw file
Yes, I will update the text.
sorry to start a conversation on this, but I was just thinking that if you need to give a folder path, that needs to be clarified somehow. Reason is, that many people have folders with multiple .epw files, and I am not sure how that will work (which of the files is picked up, probably 1st alphabetical).
Maybe it would make more sense to ask actually for a file path for the epw file? Then any stat, ddy files can be picked up by name in the same folder?
just a though
Yes, this is actually a good idea. This will need support from @chriswmackey to update the cli command.
Fair enough. I made the change here:
… and this will just mean that you get an error thrown if there isn’t a .stat and .ddy file in the same directory that have the same name as the .epw. You’ll be able to get the change on your end by running the LB Versioner and restarting Rhino.
From my tests, it seems that @mingbo does not have to change anything on his end except possibly updating the descriptions.
Thank you @chriswmackey for the quick fix.
Works fine.
Regarding the no .stat or .ddy files, do you think that should be an error instead of a warming? I am asking because now I get an error and the epw is not passed through at all (if the other files are not available).
In most non-E+ recipes, the .epw is enough to run the simulation, and even the E+ ones have the capability to run without a .ddy (albeit with a warning and possible effects).
Maybe I’m misunderstanding but it is currently implemented as an error. And this is how I think it should be since, if you are assigning a global definition of weather that lives with the 3dm model file and assigns all default weather-related values, then this should be a complete definition of weather that gives you all of the default values.
Of course, every recipe and environmental analysis command has it’s own input that lives apart from this global definition of weather in project information. If all that you have is one of the 3 weather files and all that the recipe needs is the same one of those 3 files, then each recipe or the environmental analysis command let you specify the file.
