Hi all, I am having some issues whereby some apertures and doors hosted on internal walls, appear as outdoor surfaces. I have try to rebuild the rooms and apertures/doors and then run solve adjacencies but it is still not working. This is issue is creating fatal error when validating model. I have tried to change the boundary condition of the aperture/doors manually but I get another adjacency error. I am happy to share the model through a private link as it is a confidential project.
Hi @ffotsing99,
This is most likely the result of small gaps between the walls or the apertures/doors not being the same between the two.
If you share the model with me, I will be more than happy to take a closer look.
For future reference, the issue in this model was the result of unmatched windows and misaligned rooms.
After fixing those issues the solve adjacency was resolved without issues.
We also added a new command to automatically match the apertures and doors between the rooms. The command is PO_MatchChildObjects and is available in version 1.51.2 and newer.
