I accidentally had window families imported multiple times. Which is now causing validation problems. I am unable to delete the windows- or at least I can not. How can I remove all of the windows and start over for windows only?
Hi @cemresonmez,
There are 3 different ways that you can do this:
- Use the
Overwrite existing openingsin Revit connector when adding the openings to the rooms. That will overwrite all the existing doors and windows and add the new ones. - Use the
Remove small openingscommand with a very large value to remove all the doors and windows from your model. - Use the
Repair invalid windowscommand. Since these openings are invalid, this command will remove the duplicate ones and only keep one of them.
