jriise
(Julian Riise)
1
Need help setting the CPU parameters when calling the Pollination API. Any documentation on this topic?
I imagine there is a method to do this somewhere? Seeing an example would be very helpful.
Some context from my script:
if __name__ == '__main__':
project = Payload.Create(
name=project_name,
description='A test project',
public=False
res: Any = create_project(client, project)
print(res.json())
recipe_filter: Payload.RecipeFilter = Payload.RecipeFilter(
owner='ladybug-tools',
name='annual-daylight',
tag='0.9.13'
job: Payload.Job = Payload.Job(source=recipe_source_url, arguments=arguments)
res: Any = client.create_job(project.name, job)
mostapha
(Mostapha)
2
Hi @jriise,
Here is a code sample that shows how to submit a study to Pollination using the API:
The daylighting recipes have an input for cpu_count that can be used to set the number of CPUs for the run. See these lines in the code.
recipe_inputs = {
'model': None,
'model_id': None,
'min-sensor-count': 1000,
'cpu-count': 20 # you can set the number of CPUs here
