Results From Post Parametric Run
Trying to get the results from a post parametric run but the components have changed since the last time i used it and have been unable to get them.
Theres no “results” from the Check Run Results component and Load Assets components. Was able to get the model but nothing else really. Quite Lost here.
Hey @cflynn29,
What is the error message from the components? Your overall workflow looks correct.
Hi @cflynn29,
The lack of the “results” output suggests that you are not using the recipe with the -full tag.
You can read more about why we created a separate tag that returns the results folder as well in this topic.
If the -full tag version of the recipe is not already added to the project, you can select the -viz tag or even the version without a tag, and then change the tag as shown in the video below.
