Revit cannot run the external application
Hello, I have just installed the pollination plugin for Revit 2023 and am receiving an error that was last addressed in 2021. I reviewed the solutions to those errors and I think since then the stated changes were implemented such that i the solutions might be outdated. Here is a screenshot of the error. Is the issue still potentially my anti-virus blocking a particular file?
Hi @aislas,
This is most likely a conflict issue with another Revit Addin. It looks like an older version of Nlog is loaded.
Can you try to add an underscore before the Pollination addin name? See here for more information:
In the case of Revit 2023, the path to the file is C:\ProgramData\Autodesk\Revit\Addins\2023\Pollination.Revit.addin.
Hi @mostapha I think you were correct. I disabled the Pirros plugin and things are operating normally. Thank you!
Hey @mostapha I was needing to use both the pirros and pollination plugins (for separate projects) on the same version of Revit. I went ahead and modified the file name _Pollination.Revit.addin. This did allow me to load pollination, but when I attempted to use the model editor i recieved multiple engine errors :(. I have included a copy of my log to show these.
2025.11.19 10_02_16.812.log (74.7 KB)
When i renamed the file back to its original name without the underscore, the app ran smoothly again. Will I need to toggle between changing the file name each time I want to use pollination with other addins for now? Is there a more permanent fix I can use?
Hey @aislas,
Thank you for sharing the logs. From what I can see the issue doesn’t have to do with renaming the package. You just need a few restarts to make sure all the necessary libraries are downloaded for the Model Editor. This is a one time action that happens after every installation.
To test this, can you rename the .addin file, and then try to open the Model Editor Desktop application? You should be able to use the Model Editor regardless of the name of the addin.
@antonellodinunzio and @mingbo, please correct me if you believe any of my assumptions here are incorrect.
