I am using the Revit Plugin to Export an Architecture model for energy modeling. When I click on Manage Room Geometry I see a list of all the rooms. But when I click Export Model there are no rooms appearing. Additionally, when I try to manually select the rooms, they are also none added to the Export Model Room/Space Selections frame. Am I doing something wrong?
Unfortunately, the project is for the government and I cannot share it for troubleshooting.
This is most likely because Revit’s task queue gets stuck. Can you try to click in the viewport and zoom in/out a bit? That way Revit will retrigger the tasks and it should start parsing the rooms.
Unfortunately, clicking in the viewport and refreshing the Revit scene has not solved the problem.
I’ve tried the model in 3D and a floorplan of a single floor. Since this is a very large model, I also tried manually selecting a few rooms but still no luck.
Hi @alexsunny123, since I made this post there have been several updates to the Revit Pollination plugin that has improved performance. I have been able to load models with hundreds of rooms now without issue.
