Hello all.
Today suddenly I am getting this error with Revit pollination plugin while opening Revit 2024.
Hello all.
This is most likely a conflict with another plugin. Any chance that you have the ClimateStudio Revit plugin also installed?
Yes @mostapha but that’s a Rhino Plugin. Any workaround? Revit exporter automatically get installed to Revit.
What shall I do now, pollination is not loading
We just released a new version of the Revit plugin (v2.187.1) that has a more relaxed dependency version for Eto. This should hopefully resolve the conflict issue.
If this doesn’t work, then the only way to get it to work is to uninstall the ClimateStudio Revit plugin. I’m afraid there is not much that we can do here with the DLL conflicts.
You can manually remove the folder from Revit’s plugins folder, so it doesn’t load to Revit.
Hi @mostapha . Thank you for the update but unfortunately this didnt solved the issue. I had to delete the CS Revit Plugin.
This issue should be fixed now. Try v2.218.3 or higher.
