Rhino Plugin Installation Error "ID already in use"
Hi @jroberts,
I meant the software registry. Here is the process to check the registry path from inside the Rhino plugin.
I suspect the plugin is loaded from some other path. If it is loaded from Rhino 6 folder instead of Rhino 7 then you should only install it for Rhino 7. The installer provides an option for that.
