Room grey out and can not be selected
Hi everyone,
I have encourtered a problem where one of the room turns grey and can not be selected.
I guess this has something to do with layers, as when I change the layer color to red, this room does not change with the rest of the items. But I can’t fix the problem, because if I turn off the layer, this room disappear at the same time. No other layer contains this room.
Does someone know how to fix this?
Thanks
Hi @cyaandzebra, can you share a screenshot?
Did you try theunlock command? You might have locked the room.
It can only happen if you are in the InPlaceEdit mode to edit a single Pollination room.
