Room List Not Processing -Revit Plugin - Export - Room Selection & Property Override -
Hello Pollination folks!
When setting up the an export the Room Selection & Property Overrides Room list never populates, Getting Hung when “Processing Rooms”
Works fine in other places.
Thanks in advanced,
Geoffrey A. Tears
Hi @microgtears, which version of the Revit plugin are you using? Can you ensure that it is the latest version? You can download the latest version from the announcement page.
If you’re already using the latest version is it possible for you to share the model so we can try it on our side? You can send it via a private message if you can’t share the model publicly.
@mostapha Thank you for the quick response. Your are correct; I had to update the plug-in.
Thanks again! Excited to be testing Pollination!
Geoff
