I am trying to run a series of IDFs through energy plus after creating it using the HB Model to OSM (I will be editing the IDF before running it through E+).
My understanding is that the pollination recipe for this would be the run-energyplus component, and have managed to get this to work if I use a simple box model, but as soon as I use this recipe for a more complicated model, it stops working. I have tried running the IDF before making edits, and after making edits to the OSM generated IDF.
If I run the exact same IDF through the honeybee HB Run IDF component, it works, which is what confuses me.
Does anybody know why I am experiencing this issue?
in.idf (566.0 KB)
I was also wondering if there is a way to debug any errors with the pollination equivalent of the HB Run IDF component? The HB component has a report output of all the warnings and errors, but the pollination equivalent only has the debug tree structure on the webpage that is common to all pollination recipes, which I haven’t quite understood how to use.
