Have you ever tried running public recipes with the “run locally” option (Rhino WIP)? I’m having difficulty running the annual daylight recipe from my local system. The simulation ends in less than 10 seconds with the errors shown below.
To my understanding, a similar error was reported before for large models and all of the latest Radiance recipes on Pollination had been updated for the workflow. So, I might be missing something else.
This is most likely because the version of honeybee-radiance that is installed with the version of Rhino plugin that you are using is older than the version of honeybee-radiance that is used by the recipe. The easiest way to fix this issue is to install the latest version of the Rhino plugin. I just tested it locally and it worked as expected.
@chriswmackey - this is one of those cases that is not easy to catch for us, and the reason that I think we should use containers for running the recipes locally.
@mingbo, there is a bug for loading the results locally after the simulation is finished. It is not looking into the right directory. I will document it for you separately.
