Runs Failing - Not sure why
Hi @mostapha and team could you please look into this job and why some of the runs are failing? Is the issue on my side or is it something else?
Pollination Cloud App
Thank you,
Patryk
Hi, @adaptis! Let me check this and get back to you.
Hi @adaptis! I doubled check the failed runs and it happens because your job is technically too large for a professional account with 48 parallel CPUs. What happened is that those 11 simulations out of 360 were timed-out. I re-ran them manually for now and they ran successfully. You should be able to download the results for them.
