Is it possible to keep them in the model when face direction is changed?
Hi @martin6, how are you changing the direction of the shade? I imagine you are using the Dir
command to flip them.
Try using the flip
command instead and it should work with no issues.
@mingbo, FYI!
Yes you guessed right I use the Dir
command to flip them. Thank you @mostapha for the hint.
@mingbo Iād still prefer to have them both working.
Dir
command is also supported now.
