@mingbo - did you have a moment to review this case?
I’m assigning this to Mingbo so it doesn’t get lost.
Hi @victorbrac,
Sorry for the late reply. I have been thinking about this command about whether it should split child objects.
One of the main reasons that I was reluctant to split apertures/doors within “PO_SplitRooms” is it would create “invalid” apertures/doors that contain edges that touch the room face’s boundary, and the “PO_OffsetChildObjects” command doesn’t work nicely in this case.
Recently, we have just improved the “PO_OffsetChildObjects” command with a robust solution, and now I am able to revisit this issue again.
Here is a demo of the improved “PO_SplitRooms” command work with “PO_OffsetChildObjects” command.
A post was split to a new topic: Add a default input for Offset Child objects to PO_SplitRooms command
