Is it intended that the snapshots disappear from the Roaming App Data folder? I created one yesterday and exported to GEM, but I wanted to go back and make an edit. Now not only does it not show up in my snapshot editor, but the file is gone from the App Data folder. Is this an intended feature that snapshots are deleted at some point or a bug?
I found the snapshots now, but why do they not show up still to select from in snapshot editor?
Hi @crduggin, we do not delete any of the snapshots unless you delete them from the interface.
The information of the snapshots for each Revit model is stored in the Revit file. To make sure they show up the next time you open the same Revit file you need to save the Revit file itself. Did you save the Revit file?
This will all get much better in the next upcoming release. The user will pick up the folder for saving the snapshots, and there is also an option for loading the snapshots from a folder.
Not my best design decision! ![]()
