Solution exception:object of type 'NoneType' has no len()
Hi all
any idea what this is about? Seems to be connected to the latest update
Hi @martin6! Thank you for reporting this issue. This seems to be mostly an issue with the LBT Grasshopper plugin - how do we recreate it from the Rhino plugin side?
I did simulations with 0.130.2.0 today. Was able to load and work with them afterwards.
Now updated to 0.130.3.0 I get this message.
You can try any of these files here
I also get the message when I run a local simulation.
Switched back to previous now it is not so much fun but it works :wink:
Hi @martin6 ,
Thank you for reporting this issue and I apologize for the late response. It’s a bug was caused by something that I added this past weekend. I just pushed a fix:
… and it will be in the next Rhino plugin release. In the meantime, you can get the fix by running the LB Versioner and restarting Rhino.
For finding this bug, you get the honor of “person creating the larges E+ sql files with the latest version of the plugin” :slight_smile:
Thanks again!
