Split the windows
Hello,
i m working with the rhino plug in and i have got a big window that i want to split multiple times.
if i trim it, it becomes a panels, and looks like it is not recognised anymore from the plug in.
is there a polliantion command, or a better way I can use to split an existing window without cancelling it and re-make for the entire facade ?
I hope this is clear. pls refer to the screenshot to understand.
Thank you!
Hi @giuseppe92,
We don’t have an automated command but you can do it manually fairly quickly. Here is a video that shows the process.
