Thank you very much! The code requires a list of HBJSON files, which I believe can be generated from the ModelToOSM component. However, I am not sure if there is another way to create HBJSON files without using the ModelToOSM component. In my current workflow, I am iterating through an Excel file using Collibri, recording the jobs, and then using Pollinate. Can you suggest an alternative method? I apologize for my limited knowledge as I have only been using Grasshopper and Ladybug/Honeybee tools for a few months.
Hi @prateekwahi, you can use the Dump Objects component to save the models as HBJSON. It should be times faster than the ModelToOSM component.
