The Rhino plugin only adds the results for October at 3:30 PM for abnt-nbr-15575-daylight recipe
I’m unable to add the recipe results to Rhino. When I try to “Add” the evaluated times, only one layer is created for the result from October at 3:30 PM. I can view the results for all times and dates, but I can’t add them to Rhino.
Hi @sagabps, did you check the Rhino layers? If I remember correctly, they are baked into separate layers and only one will be on.
Yes. Only one layer was created for October at 3:30 PM.
Thank you, @sagabps! This looks like a bug. @mikkel documented this and we will have a look and get back to you. Meanwhile, you should be able to use the Grasshopper plugin to load and back the results. Do you know how to do that?
Alright! I don’t know.
Is there any tutorial available?
Hi @sagabps,
If you update your core libraries with LB Versioner, you should be able add the visualization with all the data. You have to run a new study to get a new visualization – you cannot use existing studies.
Hi @sagabps, Did updating the installation solve this issue? Let us know if you still facing a problem in baking the results.
