Transfer honeybee model from grasshopper to rhino pollination
Hi @kuan,
I was able to add the window with no issues. I use Rhino 8 and the latest version of the Rhino plugin.
I zipped the 3dm file so I can upload it here:
20260113_Pollination_testmodel_v7.zip (9.4 MB)
We have changed the UI a long time ago. You should us PO_Panel instead.
You can find the answer to this question on the Ladybug Tools forum. The easiest way to fix this is to change the shadow calculation method to pixel counting method. See here:
