@mingbo I am still a bit confused with the use of U-Factor and U-Value in Pollination.
If I follow this conversation then the results for a factor is supposed to be higher then the one for a value due to the air film?
Which is not the case right now. Or am I missing something?
I personally am adapted to the thinking a factor is something out of a construction, while a value belongs to a single item.
I know the terms are not totally fixed but doesn’t it make sense to keep it one way in Ladybug.
