Update Room Properties from Grasshopper
How do I update room properties through grasshopper?
For example, this script below does not change the display name in the Rhino Pollination panel:
import rhinoscriptsyntax as rs
for room in rooms:
   name = room.display_name
   if name == "P3":
       room.display_name = "new name"
is there a way to commit the changes back to the model?
You can use the PO_Model component to replace the model in Rhino.
