Hi @adammer, I’m working on the document for writing Recipes and sorry that it’s taking longer than expected.
The short answer is that each command runs inside a [Docker] container and as long as you can create an image for the library you can execute it on Pollination. In your case you can use VTK or ParaView’s Docker image. The place to set up the image is the Plugin.
Here is the longer answer:
A Recipe is a collection of DAGs and a DAG is a collection of tasks. Each task uses a Function as a template. And each Function is part of a Plugin. When you execute a command - it technically get’s executed inside the Function and the Function uses Plugin’s [Docker] image to execute the task!
This means you need to create a Plugin with those Functions and use the Paraview or VTK docker image for that plugin.
I know that I introduced so many concepts in two paragraphs. Let’s use honeybee-energy as an example. It’s a plugin that includes several functions for energy simulation Recipes. Here is the repository:
If you check the __init__.py file you will see that the image for this plugin is set to ladybugtools/honeybee-energy.
# this is a facny way to get the version for the docker image
# the results is something like ladybugtools/honeybee-energy:1.69.2
image_id = get_docker_image_from_dependency(
__package__, 'honeybee-energy', 'ladybugtools'
__pollination__ = {
'config': {
'docker': {
'image': image_id,
'workdir': '/home/ladybugbot/run'
Not your fault! We should have a better documentation. I’m half way there. We were not expecting someone to be so brave to want to write a recipe right away! Thank you for being patient with us. Getting there …
