jaclu
(Jacqueline Lu)
May 10, 2022, 11:51am
1
Hi @chriswmackey ! You had implemented the ability to input radiance model folder into all pollination recipes last month.
Just tried testing it out on the issue I was having previously but it still persists.
I have run the LB versioner and LB Sync Grasshopper File and restarted rhino.
Both direct sunlight recipes show the same error.
Jacqueline
mostapha
(Mostapha)
May 10, 2022, 1:13pm
3
This is most likely because of the built-in check for input file types which should be an easy fix. I assigned this topic to @chriswmackey to have a look.
Thanks for letting us know, @jaclu . I just pushed a fix for this:
pollination:master ← chriswmackey:master
opened 04:52PM - 10 May 22 UTC
So just use version 0.5.3 or 0.5.3-viz of that recipe and it will accept the model folder as input.
