Hi @antoinedao , I just tried to run UTCI recipe and I am getting the same error at run-comfort-map. There are no logs to indicate why it is failing. Could you help me understand why this is happening. Thank you
Hi @hmurya, we are looking into this and will let you know the reason when we know more. At the minimum you should get the logs for the error. Stay tuned!
I have similar problem but i don’t know if that related to the gh definition or a bug in Pollination?
Hi @seghier, as discussed in the other topic this is an issue with one of the final steps of the recipe that needs to be optimized.
