UWG sample error
Hello,
I wanted to play with the new LB Samples component (thank you @mingbo), and randomly dropped the DF_UWG sample, and got an error. (I did no changed to the file, just got the error by opening the sample file)
Should be an easy fix. I just wanted to notify you.
Thanks, @byron .
It looks like this was a bug that was introduced back in April when I added support for using meshes in Dragonfly context geometry. I just pushed a fix here:
Thanks again!
oh, great. Thanks @chriswmackey for the very quick fix. I didn’t check github at all.
I run versioner and now it works fine. :ok_hand:
minor comment on another sample (DF_alternative_weather). The file path internalised at the start of the script goes to your github local folder.
I could easily find the csv in the sample folder, but maybe you could have a description/guide next to it? Unless it was intentionaly left like that.
Thanks, @byron ,
That’s a good idea to update the link to the weather data now that we’re certain that the vast majority of people will have it in their program files. I updated the the sample file here:
You won’t see it officially updated until we do a LBT 1.9 release (when I go through and update all components in all of the files). But I’m glad that you pointed it out since this is good practice going forward.
Thanks again @chriswmackey
