I am trying to download a job from Pollination. I am logged on, and when I double click the “Check Job Status” component I can select the job and the component recognises it.
However, when I enter the job ID manually I get an error message.
Am I entering the ID wrongly?
Hi @Max, you can either select the project from the UI or use the full ID. Since it’s a public project I can also pull it down. Here is your project:
I selected it from the UI and then used Grasshopper’s Extract parameter option to get it as an input component.
Extract parameter
