ValueError: All sensor grids were filtered out of the model folder!
I tried a sample model of 2 rooms, the rooms were build from individual surfaces rather than solid boxes, and I had created grid through LB generate point grid, giving the floor surfaces as base geometry.
The model ran successfully on the cloud.
However, I am not getting any results on the local run. I check the logs and found this error ‘ValueError: All sensor grids were filtered out of the model folder!’
Looking for some guidance for the same.
Thank you!
Hi @ishitasingh,
Can you check the input for grid-filter and ensure it is set to * similar to what you have for your cloud run?
Thanks @mostapha !
That worked!.
