Walls missing but show as room bounding
What would cause these walls to not show up? They show as room bounding in revit.
Hi @crduggin,
Glad to see your first question on the forum! :slight_smile:
This might be a bug in the viewer. Are they missing when you export them to a GEM file?
If that’s the case can you export those few rooms as an HBJSON and share it with us for debugging? Thanks!
I was about to test that exactly when i got the fatal error, so I will have to get it pulled up again.
Sorry about that! As always, it will be helpful if you can share the model or the logs with us so we can recreate the error on our end.
Must have been a viewer error because it looked fine in viewer and exported right when i reopened the model.
