Priority: CategoryIcon
Call PollinationLogger.LogHelper.OneTimeSetup(ILoggerFactory loggerFactory) to setup global loggerFactory first. (Parameter '\_loggerFactory')
ArgumentNullException
Any idea ?
Any idea ?
Hi @thomaslagarde, this has come up in the past. I think it is most likely a dependency conflict but I’m not sure. I’m assigning this item to @mingbo to help.
I uninstalled pollination, the warning disappeared.
Reinstalled from a fresh download, the warning came back.
What are the other plugins that you have installed? It is most likely a conflict between Pollination and one of the plugins that you already have installed.
