WELL Daylighting Recipe
Hello,
I would like to use the Pollination recipe for WELL daylight assessments but I would like to confirm what the sDA values are being used for the assessment. As the WELL criteria can be updated quarterly, it would be great if this could be visible to ensure we are using the correct version.
Also, during one of the latest updates, the L01 feature got updated from sDA 200,40% > 30% to sDA150,50%>30%. Would it be possible to update the recipe to also have this option?
Many thanks!
Pauline
Hi @pramos,
I can update the recipe to include the sDA150,50% > 30% threshold.
Regarding your first point, I’ll look into the best way to make the sDA values and WELL criteria version visible so users can easily confirm which standard the recipe is aligned with.
Hi @mikkel,
Thank you very much!
Hi @pramos,
In the latest version of the recipe I have updated the thresholds. There is also a new recipe output file called “well_version” in which you can dig deeper and find the version and the threshold values used in the calculation.
If you run the recipe locally you need to either update your core libraries with LB Versioner or wait for a new Pollination installer.
Thank you, @mikkel!
Rhino plugin installer version 1.65.29 is available to download and includes all the latest updates to the libraries and the recipe.
