What are the limit offset and base offset referred to in the setting?
Hi Mostapha, I have one thing to clarify in the Revit pollination setting. What are the limit offset and base offset referred to in the setting?
Screenshot 2022-07-25 171342
Hi @herosh! They define the upper boundary of the room. They are the same as what you see in Room Properties.
The Revit documentation is here:
https://help.autodesk.com/view/RVT/2020/ENU/?guid=GUID-C3040C34-62FC-4F31-9594-1082CFF86FFE
