I have a Revit model with many types of window systems with top and bottom as solid panels and glass in the middle. I guess the Revit Plugin export reads the window system as a whole glazing system and so it is exported as all glass? Is there a way to export only the glazing part of window system as glass and the top/bottom panel as wall? The last thing I would want to do is to export and fix this manually.
