When i go through the select apertures, it seems to work fine. They are counted and are displaying in the view tab. I press “ok” to consider them in the model.
Then when i go through the room creating process, no aperture is linked to any room ( therefore not being displayed in the view tab either):
Did you make sure to change the apertures state to Export? Is your case similar to this? This is a recent change in the UI and can be confusing if you have used the plugin before we made the change.
