Windrose legend issue
There is also another issue with LegendParameters - the minimum and maximum functions do not work - this can be a new topic though -
with st.expander('Windrose'):
        windrose_st_month = st.number_input(
            'Start month', min_value=1, max_value=12, value=1, key='windrose_st_month')
        windrose_end_month = st.number_input(
            'End month', min_value=1, max_value=12, value=12, key='windrose_end_month')
        windrose_st_day = st.number_input(
            'Start day', min_value=1, max_value=31, value=1, key='windrose_st_day')
        windrose_end_day = st.number_input(
            'End day', min_value=1, max_value=31, value=31, key='windrose_end_day')
        windrose_st_hour = st.number_input(
            'Start hour', min_value=0, max_value=23, value=0, key='windrose_st_hour')
        windrose_end_hour = st.number_input(
            'End hour', min_value=0, max_value=23, value=23, key='windrose_end_hour')
def get_windrose_figure_temp(st_month: int, st_day: int, st_hour: int, end_month: int,
                    end_day: int, end_hour: int, _epw, global_colorset) -> Figure:
    """Create windrose figure.
    Args:
        st_month: A number representing the start month.
        st_day: A number representing the start day.
        st_hour: A number representing the start hour.
        end_month: A number representing the end month.
        end_day: A number representing the end day.
        end_hour: A number representing the end hour.
        epw: An EPW object.
        global_colorset: A string representing the name of a Colorset.
    Returns:
        A plotly figure.
    lb_ap = AnalysisPeriod(st_month, st_day, st_hour, end_month, end_day, end_hour)
    fields = get_fields()
    windrose_data = SI_IP_Check(_epw.import_data_by_field(fields['Dry Bulb Temperature']))
    wind_dir = _epw.wind_direction.filter_by_analysis_period(lb_ap)
    windrose_dbt_ = windrose_data.filter_by_analysis_period(lb_ap)
    lb_lp = LegendParameters(colors=colorsets[global_colorset], max = 60)
    lb_windrose_temp = WindRose(wind_dir,windrose_dbt_)
    lb_windrose_temp.legend_parameters = lb_lp
    return lb_windrose_temp.plot(title='Wind Direction vs. Dry Bulb Temperature', show_title=True)
windrose_figure_temp = get_windrose_figure_temp(windrose_st_month, windrose_st_day, windrose_st_hour, windrose_end_month,
                                              windrose_end_day, windrose_end_hour, global_epw, global_colorset)
st.plotly_chart(windrose_figure_temp, use_container_width=True,
                        config=get_figure_config(f'Windrose_{global_epw.location.city}'))
Can you please share a minimum complete script that I can use to re-produce the issue. A minimum complete script will have all the necessary libraries and functions imported.
What you shared seems like a snippet from your Streamlit app. I could not get it to work right away.
Thanks @devang - I hope this helps
from ladybug.windrose import WindRose
from ladybug.analysisperiod import AnalysisPeriod
from ladybug.legend import LegendParameters
from ladybug.epw import EPWFields
from ladybug.color import Colorset, Color
from ladybug.datacollection import HourlyContinuousCollection
epw_file = './assets/sample.epw'
global_epw = EPW(epw_file)
@st.cache_data(ttl=2)
    Args:
        epw: An EPW object.
    Returns:
        A plotly figure.
    windrose_data = _epw.import_data_by_field(fields['Dry Bulb Temperature'])
Not. It wasn’t a complete minimum script that someone can use right away. Fortunately, I knew that you had used functions from the Weather-report app. So I could get the functions.
Following is an example of a complete minimum script that anyone can just use.
import streamlit as st
from plotly.graph_objs import Figure
epw_file = 'path to EPW file'
def get_fields() -> dict:
    # A dictionary of EPW variable name to its corresponding field number
    return {EPWFields._fields[i]['name'].name: i for i in range(6, 34)}
colorsets = {
    'original': Colorset.original(),
    'nuanced': Colorset.nuanced(),
    'annual_comfort': Colorset.annual_comfort(),
    'benefit': Colorset.benefit(),
    'benefit_harm': Colorset.benefit_harm(),
    'black_to_white': Colorset.black_to_white(),
    'blue_green_red': Colorset.blue_green_red(),
    'cloud_cover': Colorset.cloud_cover(),
    'cold_sensation': Colorset.cold_sensation(),
    'ecotect': Colorset.ecotect(),
    'energy_balance': Colorset.energy_balance(),
    'energy_balance_storage': Colorset.energy_balance_storage(),
    'glare_study': Colorset.glare_study(),
    'harm': Colorset.harm(),
    'heat_sensation': Colorset.heat_sensation(),
    'multi_colored': Colorset.multi_colored(),
    'multicolored_2': Colorset.multicolored_2(),
    'multicolored_3': Colorset.multicolored_3(),
    'openstudio_palette': Colorset.openstudio_palette(),
    'peak_load_balance': Colorset.peak_load_balance(),
    'shade_benefit': Colorset.shade_benefit(),
    'shade_benefit_harm': Colorset.shade_benefit_harm(),
    'shade_harm': Colorset.shade_harm(),
    'shadow_study': Colorset.shadow_study(),
    'therm': Colorset.therm(),
    'thermal_comfort': Colorset.thermal_comfort(),
    'view_study': Colorset.view_study()
def get_figure_config(title: str) -> dict:
    """Set figure config so that a figure can be downloaded as SVG."""
    return {
        'toImageButtonOptions': {
            'format': 'svg',  # one of png, svg, jpeg, webp
            'filename': title,
            'height': 350,
            'width': 700,
            'scale': 1  # Multiply title/legend/axis/canvas sizes by this factor
global_colorset = colorsets['original']
    Args:
        epw: An EPW object.
    Returns:
        A plotly figure.
    lb_lp = LegendParameters(colors=global_colorset, max = 60)
                                 show_title=True)
I understand what you are trying to achieve here. I am sorry to report that, we have not added the capability to load other data on top of Windrose chart yet.
Sorry @devang - I have a very messy script which I might have missed some of the functions but yes, you’re re right the basis is the one you provided before -
To make it clearer, the issue is not about the Windrose itself, it’s about the LegendParameters minimum and maximum values - I can plot DBT on top of Windrose and it works in C - but when I change the units to F, I have to adjust the min/max values accordingly for LP which doesnt work -
below is based on C unit which works fine -
or maybe this is sth that is not related to ladybug_charts, and @chriswmackey might be able to help as it sits under ladybug core module - not too sure -
This is a limitation of ladybug-charts. I will look into this.
Pushed a fix. Will share once merged. Thank you for your patience.
Try with version 1.19.3
it works perfectly fine now - thanks a lot @devang
