but i logged in with my pollination account through pollinate component.
and also, i cannot find [ladybug fly] compoenet in GH that can create parametric designs as showed on the official tutorial
Hi @alex999, can you send a screenshot of the Recipe component and the Pollinate component? Do they give you the message that you are logged in?
The error message is because the component is failing to add the recipe to your project. Since it is a personal project the recipe should be added with no issues but for some reason it is failing.
Hmm. Am I right that it used to work before? Did you install a new Anti Virus that might be blocking the process? Let me know if you want to set up a 1 on 1 call so we can help you with this. You can right-click on my profile picture and send a private message.
